1, All the wires were soldered to ensure a good connection and most of the loom came from the same car so all the wires mated up colour for colour so they had to be rite?
2, The ground was the earth supply that the std coil was running same one as the esc module was using which is the std earth point on the car as it is a mk4 escort which comes with the module as std so the original edis mounting holes on the inner wing were utilised also.
3, I will be a few days before i can get to the car as its now in the ownership of someone else running the esc module originally fitted to keep it mobile, but i will indeed go over it all to check to see whats giving the correct outputs or not.
4, The wires supplying the power and earth to the module are the std 12v supply that normally feed the std coil that runs a dizzy.
I remember reading somewhere that you can run the edis module in limp mode as a temperary method of getting the car mobile so would have thought it would graft up straight away but this is what happend for me so thought i was wrong.
i do however have about 1/2 a dozen edis modules including various coil and vr sensor plugs so i will make another up to see if it was just a simple mistake on my behalf.
Q, if i make up a loom WITHOUT the vr sesor wire shielded will it still run as some of the older edis set ups had an unshielded wiring as std so would think this would be ok but not advisable??
GAT.
