today was the big day.... I took the car to school (Im a high school teacher) and the machine went pretty well.... It really does run better when it warms up.... Has a stutter when its cold.... Sorta like a rev limiter but at around 2200prm... No clue what rpm yet as my laptop has a crook battery and I haven't got a tacho yet.... But once the POS warms up the stutter is all but gone.... It is running a little on the rich side, so have ordered a range of main jets... I think the stutter could also be because of the slightly rich mixture....
Also.... It starts fine, and idles well.... The idle problems I had before were mostly down to a very tight accelerator cable/linkage.... And possibly because it was all little dry and tight from lack of use.... All good there now....
Now for the ignition.... Still not sure how it is going.... As I haven't been able to do any data logging, I really have no clue if the map is even close.... I think I based mine on DannyP's map, but I reduced the initial a little... Volksnut.... Do you have a screen grab of you current map?.... I know this is all a bit dangerous since I haven't done any logging, but what sort of things should I be aiming for when it comes to load v rpm?... Currently the 500rpm stage is set at 8, 600 at 9, 800 from 11 to 15, 1000 9 to 18 etc.... That last one looks a little odd to me... 9 seems wrong given that at 800rpm, the advance is at 11 for load point 10 and 20... I'm prolly not making myself clear here, but I hope you guys can steer me right....
In closing.... It's got some poke!
![Very Happy :D](./images/smilies/icon_biggrin.gif)
