Originally I started out just mounting a standard Ford trigger wheel and the Ford VR sensor:
This set up used a sensor mount that clamped on the barrel of the VR sensor and replaced the timing bracket on the 1995cc/2.0 liter engines. This original setup left a few things to be desired. For one, the vee belt ran too close to the sensor, two, not every engine has the timing marker on the front seal cover.
I was not happy digging through junkyards for dirty trigger wheels so I started having my own plasma cut. I found out pretty quickly that the EDIS system and Megajolt are fairly robust with regards to the input signal and did not mind the roughness of the plasma cut wheels, or that they were only 1/8" thick. I also began mounting the sensor under the oil pan. This was less than ideal also because different gasket thicknesses resulted in different sensor offsets.
Another solution was to use two bolts on the intake side of the crank seal cover. This method worked well but was difficult to make with the drafts/angles required using a Ford sensor and if using an intake side alternator, again the sensor would foul on the vee belt.
My final ideal solution was to modify the above slightly using a sensor with a threaded barrel. This allowed for a more compact sensor mount design. In addition I started laser cutting trigger wheels. From what I can tell it doesn't make a difference to the electronics but they just look a hell of a lot better!
This mount is similar but at a 15 degree angle for clearance. Again the electronics didn't care but just in case I cut a 15 degree angle on the trigger wheel as well.
As for coil packs I've come up with a couple of solutions. The easiest way is to mount it where the distributor once lived:
If you use one of the flat bottom coils, its even easier to mount, and there is no need to change your plug wires to the goofy clip on type.
If you have any questions or need any dimensions, I am happy to help!
Happy motoring,
-Jason Miller
