New Configuration Software
Oliver Sedlacek
I've written a little DOS
Post by Oliver Sedlacek »
I've written a little DOS program that emulates a Megajolt. You're welcome to give that a try. As it runs on a PC, you need a null modem cable to link two comms ports together. I've only tested it on a Windows2000 DOS box, put if it works on that it should be fine on other flavours of Windows. Do you want to give it a try?
4600cc
SURE THING!!!
Post by 4600cc »
I wanted to write something similar. Not to emulate the entire chip, but communications only. What does yours do? I could use a special serial port driver that could redirect one port to the other. Send it to 4600cc at superford.org
AL
4600cc
Post by 4600cc »
I was busy entire month, from May 24 till now. I am still working on it. Nowadays I need to spend time connected to the box in my car. Things will be easier if I had a spare box in my hands (brend?). I might do a pre-release pretty soon. If I could get my hands on a spare box I could use while at home it would be great. Programming at night in the car or during the day in the heat is not fun, I usually just end up going to the car to test it.
I was pretty much idle since mid-May, but now I am continuing the work. I have another project coming up, will be working in prisons, mainly a female penutentury. Give it another month and I should have it ready. If someone could get me a box I could use that be awesome, will cut delivery time in half or more.
Oliver Sedlacek
I've emailed it to you.
4600cc
Can't compile
Post by 4600cc »
I can't compile the thing. I bet it's not win32. If you can, please send me executable.
AL
4600cc
Thank you.
Post by 4600cc »
Thank you for writing this. Your software greately simplifies the development of my configuration software. Since having mjsim I've made great progress in just a few hours of programming. Although the program is not perfect, for example NTVDM.EXE just going nuts while emulating this 16-bit app, it takes at least 30% of CPU out of my 2400+xp, MJSIM will be sufficient and then some for the basic version. I'm enjoying your software. Thank you very much.
AL
