Has anybody seen a TPS fitted to an SU carb?
I have twin HS4 SU's and there is only 13mm between the throttle spindle and the float bowl.
I have considered fitting it to the accelerator pedal but there is only 30 degrees of rotation. Will that be enough?
I can not use a MAP sensor because of the cam.
TPS on SU carbs
TPS on SU carbs
- spindle.jpg (128.34 KiB) Viewed 8346 times
Fitting to the pedal is generally bad news so I would suggest find a way to fit it to the carbs - either by sticking the TPS on the other end of the spindle, extending the spindle into clear space or simply swapping to a MAP sensor setup.
www.trigger-wheels.com
TPS on SU carbs
I think I will try going to a breakers, so I can measure some sensors.
I can not extend the spindel shaft because it will fowl the float bowl. (but there is 13mm to play with)
I ruled out a MAP sensor because I have a 290 degree cam.
You could also think outside the box a bit more, so to say, and fit a tps to the throttle mechanism on the carbs. It doesn't have to be attached to the end of the throttle spindle, so long as you can make an arrangement which has minimal/no play.
