UPDATE!!! It's June 2010 and the turbo is on and running a new map, I forgot how boost makes you happy
Another small step for man kind UPDATE!!!!
Another UPDATE....it's now August 2010 and I made a few runs at the track. I found 2 problems, I was running lean by the 1/8th mile and would stall after I lifted. A new higher pressure fuel pump fixed the first problem and a true BOV fixed the other. So far at 9 psi boost the best 1/8th mile pass was a 8.15 and a 13.13 @ 103 mph in the 1/4 mile. Lots of wheel spin in first and second and even a chirp in third gear all smiles here
Awesome news.... The new BOV works a little better I take it.... And how's the map working out for you?.... Getting a handle on it?.... Been looking at that vacuum manifold of yours.... I only put one manifold port in when I built my centre 'T'.... Need to add some more for the FPR and to tidy the whole lot up.... Did you make that out of PVC or something?.... I really like that.... Mind if I knock off your idea?
