I'm still plugging away but getting the feeling I'm just digging a big hole!
Summary:
No advance seen with strobe
Software ok and seeing runtime display
Tach output works (although stops at 2700rpm due to pulse width I guess - the least of my problems at the moment)
Seeing small a.c. voltage on SAW output which varies with rpm (also see the same readings at the EDIS SAW input terminal.
Have since taken the MJLJ to a friend who not only has a Scope, but knows how to use it AND has built a couple of Megasquirt units recently.
Even better that that he also has an "engine simulator" to generate PIP signals.
Hooked-up the MJ and did measurements on the SAW output and observed the SAW Pulse Widths changing with rpm changes (i.e. approx 1 sec when 10deg and approx 500mS when 40deg advance).
What I didn't note was the voltage - was a "few volts" I think.
From this we concluded that MJ was working correctly. I then hurried back home with a smile on my face and spare EDIS at my side.
Swapped the EDIS and no change
Tried yet another EDIS and still no advance
Checked-out PIP and SAW wiring again with meter but that was ok also.
Any suggestions where I go from here? (apart from the pub of course!)
The only nagging doubt in my mind is that the voltage of the SAW pulse from MJ is too low for EDIS to recognise - does anyone know what this should be when measured with a Scope?
Also, should there be a minimum distance between EDIS and Coils to prevent interference? Mine are around 6" apart could this be too close? I have used screened cable all earthed at same point.
Keith
Keith S.
