In conjunction with an EDIS, it already has RPM, Map, TPS, Temp Inputs and Aux Outputs (for Pump and Injector Drive) and nice Table Configurator Software..
You would probably need to get a WBO2 input in there somewhere.. or spec a J.A.W or Innovate WB controller for the simple vOut.
Then all you would need to do is beef up one of the outputs to drive a bank of hi-impedance Injectors in parallel fire PWM mode and write a metric assload of software.. nothing to it
The multi table, Hi-Res timing and all the acceleration, idle, Atmospheric corrections would mean a *lot* of coding work for Brent, although he could read the open source MS software to get ideas, but still, its not something Id volunteer for..
Maybe if you front him some cash to feed the family while he dissapears into code-space for 6 months you might stand a chance.. but I dont know..
