Does anyone have a useful Ignition map to get my Westfield going, as the vehicle is so light I'm after a little more advance than normal but anything to get the girl fired up would be rally appreciated.
The engine is in a mild state of tune, ported heads, hc pistons, mild cam and a 465 Holley. With the Dizzy fitted i ran 16 degrees of static which pushed it long fairly well.
Thank you for looking.
Ignition Map Westfield 3.9 V8
Hi Julian.
Did you buy the ECU from us? If so there are maps on the CD that should be good for your engine.
Chris
Chris
www.trigger-wheels.com
Hi Chris,
Thank you for replying to my post, I didn't get the ECU from you as it came to me via a Landrover lover who has swopped to a dirty diesel for off roading, however I have sourced brackets and tacho driver from you recently.
Is the CD something I can purchase from you also ?
Regards
Julian
Regards
Julian
Julswesty
Email us directly (sales@trigger-wheels.com) and we'll sort you out with a map file.
