usb driver help
john057
usb driver help
Post by john057 »
i bought a usb adapter from the autosport labs shop, when i plug it in and try to install the driver with the cd in it keeps saying, windows was not able to install your usb2.0-serial.
i have a dell studio laptop with windows vista
Hello,
Sorry you're having problems.
Before running the setup, please unplug the USB-Serial adapter from your laptop, then install the driver.
Make sure you are using the "R340" driver on the driver CD.
After installing the driver, reboot your machine if it asks you to.
Then, you should plug in the adapter. It should show up in windows device manager as a device under "Ports".
Note, the adapter currently in our store does not work with Windows 7.
john057
Post by john057 »
i followed your instructions and got the driver installed but have problems connecting to the ecu. it just says could not open port. i will try and upload a video tomorrow of what it is doing.
Hi John,
What port does Device Manager say the USB to Serial adapter is assigned to? You need to make sure the configuration software matches this port. For example, if Device Manager says COM8, set the software to use COM8.
See this part of the operation on how to set the COM port in the software.
http://www.autosportlabs.net/MJLJ_V4_Op ... erial_Port
john057
Post by john057 »
i tried that it says com20.
this is a video of whats happening... not a lot
http://www.youtube.com/watch?v=GCPncmTR5TA
Ok. What you'll want to do is go into Windows Device Manager, and under that "COM 20" change it to something sane, like com 10 or similar. The configuration software is set to only let you select a certain range of COM ports.
john057
Post by john057 »
i tried that and set it to com2 then went out to the car and plugged the usb adapter in and it said usb malfunction. i couldn't get it to work so i tried a usb adapter i got off ebay a few months ago and i got it working at last 8)
COM 2 might already be used by your computer's modem- so a higher com, between say COM 5 and COM 20 should work.
In any case, glad you got it working!
