EDIS-4 week spark
eds911915
EDIS-4 week spark
Post by eds911915 »
I finished installing/wiring in my EDIS-4 into a 1976 bmw 2002 my problem is im getting pretty good spark/ignition on cylinder 1 only. 2-3-4 very week but are there i witnessed this by using spark plug tester/simulator at night so i can really see whats going on and need less to say the motor will not start and run in this condition. could anyone give some advice on this :?:
You may want to check the coil pack wiring to make sure you have the coil pack connected according to the firing order of your cylinders.
Realize the coils fire plugs in pairs - one in the compression stroke, and the other in the exhaust stroke. Hence the term "Wasted Spark".
