36-1 wheel mounted against aluminum
Wild Bill
Post by Wild Bill »
Hi! I was wondering if an EDIS trigger will work with the wheel mounted directly to an aluminum flywheel or do I need to space it and if so how much is enough?
Thanks, Bill
That will work perfectly. Aluminum will not interfere with the trigger wheel's operation.
Wild Bill
Post by Wild Bill »
Thanks! I was pretty sure it would, just wasn't sure if there might be some voodoo waveform stuff happening. I did a Megasquirt 2 Extra distributorless 350 chevy with a LTI intake in a Porsche 944.
These next 2 engines are Aircraft 6 cyl (470 and 520 cid) for airboats so 2 edis modules each (dual plugs), single trigger and Megaspark with MAP. Should work slick!
Thanks again! Bill 8)
