Firmware upgrade DOS message
benny boy
Post by benny boy »
I've put this as a new post as I don't think its related to my other drama.
I reinstalled the v3.3.1 firmware on my v3 mjlj to rule out my rough running issue (I use v3.3.2 configurator).
Once the mjlj has been found, I get a different message - 'off key' rather than 'good'. (see attachment)
Will this give an issue, or is it just the way my laptop & mjlj are set up?
BB
Not 'good' but 'off key' ?
v3.3.1 firmware screenshot.jpg (23.51 KiB) Viewed 4269 times
benny boy
Post by benny boy »
Try these as well!
I tried to sort the 'screen freeze when I crank & run the engine' by trying configurator 3.3.1 with my 3.3.1 firmware.
Last time with config 3.3.2 it froze instantly on cranking - this time it worked for a few seconds, then froze.
The only way to unfreeze it was to pull the USB plug out, upon which it threw up the Unsupported config version.
Is that what happens when you unplug, or only if there's actually an issue?
Config timeout upon cranking and running the engine
Config timeout on engine crank & run.jpg (80.21 KiB) Viewed 4261 times
What I got when unplugging the usb...
Pop up after screen freeze then unplugging usb.jpg (25.69 KiB) Viewed 4261 times
