Misfire question... Sensor or Coil?
jamesbekman
Post by jamesbekman »
Brent I saw in a previous post that you stated that if the VR sensor mount is vibrating that it can cause a misfire. I have a rough idle, more like a miss happening... The other problem could be a coil that I can swap out.
tested plugs and wires... all is good.
Here is a video of the car at a low idle speed. about 750-850
http://www.youtube.com/watch?v=JjYIc0I7rxY&feature=plcp
Is there anything else I could look into?
James
jamesbekman
Here it is with the idle turned up and mixture leaned out a little
http://www.youtube.com/watch?v=Vleq7CN3WiA&feature=plcp
jamesbekman
Seems I have a compression issue... Pulling the head...
jamesbekman
Ends up I didnt have to pull the head. The valve wasnt closing all the way on cylinder #4. I hope to post more video of a nice idling mgb with my megajolt setup this weekend.
Wow. checking compression should be a standard question. However, many megajolt troubleshooting sessions come with the assumption that the conversion happens quickly with an engine in a known-running state. I'd imagine that some installations are on engines that haven't run for a while, or, how well it ran on distributor is not known.
