I likely will not get around to working on this until October. I returned the car to HEI so I can run my Autocross events. I looked at the car again today and the problem is still finding a suitable mount. The two coil packs tend to be heavy when trying to mount them.
Thanks for your help and opinions.
John
Megajolt or MSD problem on EDIS Corvette
The EDIS moudule will work with a variety of coil packs. you might find something lighter and with a packaging configuration that might suit your needs better.
For example the 2nd generation coil pack with flat bottom: http://www.autosportlabs.com/ford-cylin ... -p-61.html; or use 4 of the twinpost coil packs: http://www.autosportlabs.com/universal- ... -p-60.html
Keep us posted on your project!
Wiring Diagram
Here is a diagram of the system I built with 2 MSD DIS-4 modules. I am completing a digram with 1 DIS-4 module. In either case the same problem occurs.
- Dual DIS-4.jpg (203.04 KiB) Viewed 7081 times
