TPS Backwards
locost27
TPS Backwards
Post by locost27 »
Wiring in the tps. I can get power etc to it and the config reads it fine.
However when calibrating the on the lap top it says it is wired backwards. I have tried several ways and it makes no difference.
Where am I going wrong?
thanks
cng1
Post by cng1 »
Either you have got your TPS mounted back to front (and hence is being driven the wrong way) or you've got your wiring wrong.
www.trigger-wheels.com
DannyP
Post by DannyP »
Switch the power and ground wires to the TPS. It will now read the correct way. Simple.
