(Originally posted by fodderboy)
Engine Mfg: vauxhall
Engine Code: c20xe
Cylinders: 4
Displacement (cc): ??
Rev Limit: ??
TPS or MAP: MAP
Boosted or Normally Aspirated: Normally Aspirated
If Boosted- max Pressure (KPa):
Modifications: Carbs
Chassis: ??
Notes: "here is a basic map for the vauxhall c20xe running on carbs
this map is a slightly alterd version of pioneerx's vauxhall 1.8 8v map im running this map with the newest firmware version"
Vauxhall C20xe w/carbs
- vaux-opel c20xe base map.mjlj
- (794 Bytes) Downloaded 2367 times
There's an updated version of this map here, after rolling road setup:
http://www.autosportlabs.org/viewtopic.php?p=18846
