Not writing logs or sending telemetry data
raydoc
Post by raydoc »
All the lights seems to flash correctly. I have it set for CSV file. T-Mobile SIM installed and lights seem to flash happily.
Ideas? When I log in on-line there is no session to look at as the instructions say there should be.
rdoherty
Post by rdoherty »
Hi raydoc, did you add the device id to the configuration and apply it to your RaceCapture device?
Ryan Doherty
Autosports Labs
raydoc
Post by raydoc »
Yup.
rdoherty
Post by rdoherty »
What's the email address you used when creating an account on race-capture.com? I can take a look.
Also, can you upload your Race Analyzer config? Thanks!
Ryan Doherty
Autosports Labs
raydoc
Post by raydoc »
The email account is sailrad@gmail.com
I'll have to get a team mate to download the setup but it looks just like the wiki but with our device ID typed in.
rdoherty
Post by rdoherty »
Ok, I checked the website and your device hasn't connected or sent any data. Can you tell me what speed the middle LED blinks at? Different speeds mean different things:
http://www.autosportlabs.net/RaceCaptur ... metry_LEDs
Ryan Doherty
Autosports Labs
raydoc
Post by raydoc »
Slow blink, maybe one in three seconds. Left two vertical LEDS flash dimmly but quickly.
Hi Ray,
It would be good to check your RaceCapture/Pro config file. we want to make sure you're not setting a logging rate that's too high - it would overwhelm the connection.
Also, are you powered via USB only or hard wired to the car? When transmitting via telemetry, USB alone does not provide enough power.
raydoc
Post by raydoc »
I believe that all settings are like the examples for rate. How to download the configure file to post?
Read your config file from RaceCapture/Pro and then do a 'save configuration as'. You should be able to attach it to a post here.
raydoc
Post by raydoc »
Config file. The board would not accept the rcap file type so I changed it to txt. Hope it works.
Is there a way to email you the file directly?
nosm_default.txt
(7.9 KiB) Downloaded 861 times
Thanks.
You have your accelerometer and yaw settings set to 30Hz. try reducing that down to 5-10Hz per channel.
Also, you able to log to the SD card, correct?
regards,
raydoc
Post by raydoc »
Yes. Can log to SD. I'll turn them down to 10hz.
smig
Post by smig »
Hi Ray,
did you enter the Telemetry Device ID that is generated when you register your Realtime device on www.race-capture.com? If I'm reading it correctly, it's blank in your configuration:
"outputConfig" : {
"sdLoggingMode" : 1,
"telemetryMode" : 0,
"telemetryServer" : "54.245.229.2",
"telemetryDeviceId" : "",
"p2pDestAddrHigh" : 0,
"p2pDestAddrLow" : 65535
raydoc
Post by raydoc »
Several times. I even created a new one. It is connecting to t mobile but not working with your server. I am at NJMP with Lemons this weekend.
