The trigger wheel & sensors miss the chassis. Quite tight though.
EDIS4:
Is A or B right before I get tack welding done?
I can't get my head around it.
Trigger Wheel angle missing tooth
- rightwrong2.jpg (61.91 KiB) Viewed 9587 times
- Image003 (6).jpg (74.97 KiB) Viewed 9592 times
- Image003 (7).jpg (43.5 KiB) Viewed 9592 times
Can someone confirm to help me please. Is the aim to tell the megajolt that missing tooth is 90 degrees about to hit the top spot.bassboy3313 wrote:B should correct since you want the sensor to be 90 degrees (9 teeth) behind the missing tooth. Hopefully someone with a little more experience can chime in, but that is how I remember it.
Going through the installation guide it should be option B:
1.Mount the sensor in any convenient way that simplifies bracket design and accommodates mounting points on the engine block.
2.Turn the crankshaft to precise Top Dead Center (TDC) for cylinder #1.
3.Position the timing wheel onto the crank pulley with the missing tooth aligned to the sensor.
4.Now offset the the timing wheel position:
If your engine turns clockwise when facing the crank pulley, rotate the timing wheel clockwise "N" Teeth.
If your engine turns counter-clockwise when facing the crank pulley, rotate the timing wheel counter-clockwise "N" Teeth.
5.mark this final location of the sensor wheel onto the crank pulley- then weld or bolt timing wheel into place as appropriate.
And so thinks me
Alex
And so thinks me
Alex
thanks AlexAlex B wrote:Going through the installation guide it should be option B:
And so thinks me.
Alex
