The RaceAnalyzer Sensor Monitoring was a really cool feature, but operation appears rather erratic. When I open it I am usually missing a channe. Once it was once of my Accel channels. Now it's the GPS Speed channel.
If I open a second instance of the Sensor Monitor, I now have Speed, but AccelX is missing.
I'm also missing a pulse input I named "Wheel" because it gets a wheel speed signal from the speedometer.
Since there is no user interface to select which channels you want to view, I assume it should show all channels which are Enabled. Or in SW speak, it probably shows all which are !Disabled.
