Megajolt Spark Plug Conversion
damunk
Post by damunk »
From trigger-wheels I got the coil pack with the converter pieces so I can use existing spark plugs to fit the megajolt coil pack. pic below.
http://www.autosportlabs.org/files/sparkconv_205.jpg
I don't get it. The brass connector doesn't fit in the rubber. And even if it did, it would not touch the gold connections on the coil pack.
If I turn the brass connector vertical and put it into the coil pack then it is too long and you can't clip the rubber onto the coil pack. Are you supposed to cut them down?
cng1
Post by cng1 »
You should have got some instructions with the adaptors which explain how you fit them but if not let us know and we can send you another copy of them.
The terminal fits in the rubber with a 90 degree bend formed at the indentation just below the cable crimping tabs. Does that make sense?
www.trigger-wheels.com
damunk
Post by damunk »
cng1 wrote:Hi,
Got it. Don't cut them. Bend the bitches :D
