Trying to connect via Bluetooth.
Right, so I scored some old connector cables and got creative with the soldering iron. The BT-module is now connected with the RX-TX TX-RX pins of the COM port and gets 5 volts from a USB connection. I can program ports with Tera Term but I have no idea if I am only changing baud rate at the COM-port connection or if it is really done to the module. Never mind that now, what is more worrying now is the potential risk that I can't connect because the ports won't meet. The module connects itself through a newly installed COM40 port, while the Megajolt program doesn't go higher than COM20
. Is there a way to expand the number of COM ports in the MJ program to 40 or at least create an extra port?
Alex
Alex
- Contact:
I believe the problem is that one can only use the AT command set from the wired side of the BT module, that is, the side that is connected to the MJLJ module. The name can be changed from the wireless side of the connection, but nothing else. Am I mistaken?
Oops, I missed a few posts here.
Regarding the COM 40 problem. Yeah, that happens when you keep trying to make a BT connection. Windows does not have a neat solution for removing or renaming unused COM ports. It can be done but it's really stupid.
Go into device manager;
Expand [Ports (COM & LPT)] -- you will see a list of COM ports;
Select COM 1;
Click on the Port Settings tab;
Click on the Advanced button;
At the bottom you will see a box with the COM port number in it (it will say "COM1" at this time);
Click on the down arrow at the right of this box;
Click on any unused COM port that's easy to remember (such as COM99);
Click on OK;
Click on OK in the box that follows;
You have now successfully renamed COM1 to COM99.
Using this process rename COM40 to COM1;
Rename COM 39 to COM1 (if Windows asks just click on YES or OK);
Continue renaming unwanted COM ports to COM1 using the same process.
After you have finished renaming all the unwanted COM ports, use this process to rename COM99 (or whatever number you chose to rename COM1 in an earlier step) back to COM1.
Now all your unused COM ports should be freed up and COM1 is back where it was to begin with.
It's been a while since I did this on my own computers, but I think I have remembered all the steps.
Select COM 1;
Click on OK;
...Bob
- Contact:
- Contact:
Alex, that method I posted for removing unused COM ports is for Windows 7.
For Windows XP try this link -- http://www.ehow.com/how_6216286_remove- ... ws-xp.html
...Bob
Thanks for the link Bob, will try that. But first to get into the BT module on the wired side. I saw some clips on Youtube and it gave me the impression that it is possible to connect via a USB connector. But are the connections D+ and D- on the USB connector interchangeable with RX and TX on the BT module? Or are the communication protocols completely different?
Alex
Alex
- Contact:
I believe they are different protocols.
I have ordered an adapter from eBay that should allow me to use a USB port to connect with the TTL serial data on the wired side of the BT module. It was cheap enough and when it arrives I shall try this once again. The link for that adapter is --
http://www.ebay.com/itm/310742466145?ss ... 1497.l2649
-- be aware that I haven't tried this yet. I'll update after I have tried it.
...Bob
After I asked the question I found out myself that the answer is no
; when I hooked the module up to the computer through an USB connector a message popped up that an unknown USB device was detected. After that and some browsing on Youtube I found a video that mentioned using a FTDI board, which connects between a USB port and the BT module. On Ebay I found things like this:
http://www.ebay.co.uk/itm/FT232RL-FTDI- ... 5113wt_983.
A lot of BT diy gadgets loom up that are connected to Arduino. I'll wait for your result first Bob. Maybe the cable you on order has some hardware in the back of the connector, if not then it is only a connector cable for hooking up to an Arduino mother board (which also has the ability to communicate with BT modules).
Alex
Alex
If only things were simple for once. The Administrator's password is in safe mode different from normal mode
. I am using an old laptop from work and there hasn't been proper registration of all the passwords
. Time to try the even older and slower laptop with SP3 installed and a limited BT function. Never give up without a fight
Alex
Alex
