First up was the trigger wheel, the original has 2 wheels which mount inside the harmonic balancer these were removed and there was just enough room to squeeze in a wheel after turning up an adapter.
The bolt holes are all on different radius and not 90° separation, I have more pictures if you want to know how it was done.
There is about 2mm of clearance to the front cover after cleaning off the grime, I figured this will be okay as the wheel is mounted to the solid hub of the balancer.
Small solid mount for VR sensor was made to bolt on where original sensor was mounted.
More to come. If anyone sees a problem let me know so I can fix it. I am new to this stuff.
Brock
