Long story short, I've had to flash the firmware 3 times and reinstall the bootloader using the SAM-BA utility once, but now that I have a dedicated XP laptop for the RCP, I have got it running with v1.2.8.
I thought that my analog inputs were wired up out of order, but I think that might have been me being dumb.
I now see voltage leakage across the analog inputs (when I put a 12v feed onto the screw I see 3-5v across 4 of the analogs). This could be because I'm just putting the wire on the screw rather than clamping it into the connector though, so will look at that again later.
Also, I just can't get the Lua script to work at all.
I have configured GPIO3 for Output (using the jumper), and just for a test, I tried to make a Lua script [setgpio(2,1)] to make the output enable, but it doesn't seem to do anything.
Finally, I just can't get my RPM input to be read by the RCP. I have a 5v pulse signal from my ECU (2 pulses per rev), so I would expect it to be simple.
Unfortunately (because I'm not all that clued up), the tacho output from the ECU also feeds the dash tacho, and I believe it has pull up resistor connected to a 12v feed. I figured this might impact the RCP signal, so at the minute, only the RCP is connected to the tacho output from the ECU.
I see absolutely nothing on any of my RPM inputs (had them all enabled and nothing on any of them).
Is there something I am missing? I have previously seen an erratic RPM signal, but I can't remember how the car was wired at the time.
I have a very cheap scope, very little knowledge, and am considering buying one of these to try and rule out the ECU feed being the issue (which I know I can check with a scope, but I don't have sufficient knowledge to get a decent wave out of the scope):
http://www.ebay.co.uk/itm/1HZ-500KHz-DD ... 3a8d5f7f8d
Please help one frustrated person
