Hi I've just installed megajolt to my vw type1 1600 engine, running twin carbs,
I'm having a few issues, one thing I notice is that when idling at 800rpm the ignition advance display on the laptop is showing 15 degrees,
I've set the first three bins to 500, 800, and 1200. With timing of 12' 7' and 12' respectively so at 800rpm I should be seeing 7degrees or there abouts,
When I rev the engine there is a slight delay and then the advance display moves, the rpm is instant.
Could this be a map signal problem? I've tee'd the two carbs together, should I just take the vac from one side?
Thanks martin.
Timing at idle stays at 15degrees
