Interesting. Will the chart still have a visual override ?brentp wrote:So it's actually both, acting as the RCP configuration and for setting defaults system wide so when you create a chart in analysis mode or a gauge in dashboard mode it will automatically show the correct min/maxes and digits of precision - built in smarts.
Scenario 1:
Channel range is set 9-16 for an AFR meter input.
You want to rescale the graphic line chart to only show 12-13 so you can quickly locate tip in period or something to that effect.
It would seem this "global" scale wont allow that unless the analysis tool offers an override to tune in the chart to show what you want. Somewhat like what the web tool had, but the ability to type in the upper and lower would be alot more helpful than some pesky arrows that increment in a unit that is never what you want.
Phil
