RPM Signal Porsche 944
Here's how we have the test setup:
* 12v connected to unit
* PWM output looped back into the Frequency 1 channel. (see picture)
* V2.0.8 firmware / V2 app (latest available in downloads section)
* the RCP configuration (attached to this message, rename to .rcp)
The configuration above was applied so only the frequency channel was enabled.
12v was applied via terminal block and a short logging session was started immediately after that. The log file is pasted at the bottom.
If you could replicate the above and you see different results, then we should probably evaluate your unit.
"Freq1"|""|25
10204
9900
9900
10204
10204
10204
9900
10204
10204
10204
10204
9900
9900
10204
10204
10204
9900
9900
10204
10204
10204
9900
9900
10204
10204
10204
9900
9900
10204
10204
10204
9900
9900
10204
freq_test.rcp.txt
(20.34 KiB) Downloaded 748 times
L Cubed
Post by L Cubed »
Ok, should I update to firmware ver 2.0.8 for this test or repeat it the same way you did with firmware 1.2.8?
You can do both, but understand the .rcp config file will not work with the old software.
L Cubed
Post by L Cubed »
Brent,
I tried the test as you described. I attached the configuration file I used, 3 log files and a picture of the setup. Here are the details of the logs in the zip file:
RC_8: This log was recorded right after applying 12V power to the unit, with the unit wired as in the attached picture. The laptop was not connected.
RC_9: I left the 12V power connected to the unit and then disconnected the green wire from the pulse input. I reconnected the green wire to the pulse input port and then checked the sensor monitor on the computer. Then I disconnected the laptop and logged a few seconds.
RC_10: Laptop disconnected, I disconnected the 12V power leaving the green wire connected at both ends. After reconnecting the 12V power I logged this file.
From the data, only RC_9 recorded a frequency value.
Frequency Test - Luther.zip
Test File Zip
(166.94 KiB) Downloaded 1107 times
Thanks for doing that. What version firmware did you use for this test?
L Cubed
Post by L Cubed »
That was with firmware version 1.2.8.
I can flash version 2.0.8 and test that tomorrow if that will help you.
If you could, thank you.
If you see the same problem we'd like to inspect your unit directly as we haven't been able to reproduce on our side.
Are you using a 12v power supply or the car battery voltage for this last test? running car or not?
L Cubed
Post by L Cubed »
The 12V power was supplied by a DC transformer plugged into the wall, it supplies 11.5V for charging RC car batteries.
I was able to load the v2.0.8 firmware and setup a configuration but haven't been able to load the configuration to the RCP. Each time I try to load the new configuration it gets about 30% complete (based on the bar in the upper right corner) and the Race Capture App crashes with the following details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: racecapture.exe
Application Version: 0.0.2.0
Application Timestamp: 514e2c2f
Fault Module Name: python27.dll
Fault Module Version: 2.7.6150.1013
Fault Module Timestamp: 527fcf52
Exception Code: c0000005
Exception Offset: 000a312e
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
I have an autocross on Sunday so I will most likely have to move back to firmware 1.2.8 so that I can record some sweet data on my 944! :D
We're working on updated firmware and an update on the V2 app. Stand by!
Hello - We have a MK1 v2.7.7 pre-release firmware that appears to have fixed the RPM problems at RCP power-up. You can download it here:
http://dropcanvas.com/bthz0/30
If the link above is bad, you'll likely be able to download the official release in the regular downloads area.
