Help: about to do a hard reset
Hello all,
I am about to do the one thing I wasn't really looking forward to and that is a hard reset of my RCP.
After trying to access my RCP through Race Analyser and USB (which at first went without a hitch), I kept getting Unknown Error messages whenever I tried to get the two together (Read/Write/Sensors).
I confirmed a COM port had been assigned in Race Analyser and Windows (Device Manager) (both COM8) and I could see the communication being started (0%), but always followed by the error message.
I reinstalled everything on the PC, bar Windows itself. I then tried updating the firmware. But when in update mode (with the three greens leds on), Windows did not even see the COM port (System specs > Device Manager). That was visible when connected in the regular fashion!
PC specs: Windows 7 with Race Analyser 1.1.15 and RaceCapturePro-1.2.8 firmware uploader package
RCP: mine (photo attached)
Is there anything else I can try, before going down this road? I don't enjoy being this close to potentially ruining my RCP as it has made me quite happy over the past year!
Thank you in advance for any and all efforts!
With highest regards,
Michael
Michael
- RCP_Michael_20140926.jpg (249.59 KiB) Viewed 50426 times
It's not working ...
When I have 1 led Windows Device Manager shows COM10 and when connected under 3 green leds nothing.
I tried v1 and v2 and to no avail.
What do I do next?
What do I do next?
- attempt to connect on firmware 1.2.8_25m_later.png (30.15 KiB) Viewed 50385 times
- attempt to connect on firmware 2.0.8.png (27.22 KiB) Viewed 50385 times
- Device Manager 1 green led.png (54.67 KiB) Viewed 50385 times
Please try manually installing the bootloader drivers from this download:
http://autosportlabs.net/asl_dist/rcp/b ... sta7_8.zip
First unplug RCP and then run the file bootloader_drivers.exe in that zip archive.
After the drivers are installed, reboot the computer
Then hold down the button on RCP while plugging it in under windows. Do you see RCP bootloader show up in device manager?
as requested.
No AutosportLabs" bootloader under the "libusb" branch of Device Manager visible (yet).
Am going through all driver properties manually.
And Brent? Thanks!! I really appreciate your help!
Michael
Michael
- Schermafdruk 2014-09-29 19.23.32.png (115.15 KiB) Viewed 50372 times
- Schermafdruk 2014-09-29 19.23.37.png (115.6 KiB) Viewed 50372 times
Right, I've found the USB Device location and ran a "1 led" and "3 led" test.
See attachments.
Other than that, I am still clueless. Could de-installing and cleaning out the registry (regedit) help?
Thanks for all help so far ...
See attachments.
- one_led.png (33.78 KiB) Viewed 50356 times
- three_led.png (29.89 KiB) Viewed 50356 times
Found this under "Devices and Printers" (in 3 Led mode)
Unknown device "Autosport Labs bootloader"
Recognized as USB input device and HID Compliant ....
- 2014-09-29 22.07.20_bootloader.png (28.76 KiB) Viewed 50336 times
- 2014-09-29 22.07.11_under_printers.png (139.85 KiB) Viewed 50336 times
Right, it seems Windows has ID'd the RCP in 3 Led mode as the Autosport Labs Bootloader, but for reasons unknown seems insistent on referring to it as a HID device, rather than a USB device.
I have a Windows XP laptop, so I'll give that a try to, but that will be tomorrow.
For now I want to express my sincere gratitude for your help!
Michael
Michael
