Temperature Sensor - Bosch 0 280 130 023
Billy C
Post by Billy C »
Calibration table for the Bosch 0 280 130 023 Temperature Sensor and similar OEM models.
Motec lists the spec for this sensor on their webpage. The sensor drops off above 230F and below 30F but can still give a close estimate for something like oil temp.
MJLJ Bosch calibration table.txt
For MegaJolt
(1.08 KiB) Downloaded 274 times
Bosch 0 280 130 023 calibration data points.txt
For general usage
(337 Bytes) Downloaded 308 times
-Billy C
Thanks for providing this! What cars does this sensor usually show up in? We'll do a bit of research on this part #.
Billy C
Post by Billy C »
The actual brand and part # I bought was
ÜRO PARTS Part # 13621357414
From the research I could do it is similar to part
STANDARD MOTOR PRODUCTS Part # TX18
which seems to be a replacement for almost every manufacturer throughout the 80s and 90s
I'm eventually going to get a few brands of sensor and check the consistency between them but in theory the Bosch is listed as a replacement for both so the calibration should be the same.
Bosch 0 280 130 023 data sheet.pdf
Bosch 0 280 130 023 Motec data sheet
(21.04 KiB) Downloaded 272 times
-Billy C
