Megajolt with weber tps issue
Lee_edwards
Post by Lee_edwards »
Hi, I have been using my MJLJ for 2 years and it has been great, apart from when I have the software loaded up and start the car, after a few seconds I loose connection. I can only edit the software with the engine turned off.
Any ideas why?
My main reason for this post is I have just removed my bike carbs and fitted a pair of 48 dhla carbs with a new tps. When I first fitted this I calibrated the tps and it seemed to run ok! Now when I start it and rev it there seems to be a miss fire. Looking at the software and it is showing 100% throttle. I pulled the tps off an played with it in my hand and it still didn't change the readings. Unplugged it and gave it a gentle knock, refitted and it seemed to be back alive so I recalibrated it and the readings looked good. Start the engine up again, turn off and load up the software.... Back to 100% again..
I have checked the voltage between pin 1 + 2. It does move between .6v and 5v but when it's constantly showing 100% the pins read 5v and won't drop when you play with the throttle.
Any suggestions here? Looks to me like a faulty tps
Thanks lee
With regard to the software connection, are you running resistor plugs or non resistor plugs?
Resistor plugs are recommended as non-resistor plugs can wreak havoc with computer systems, especially poorly shielded / lower quality USB-Serial adapters.
On the other topic, you may very well have a faulty TPS.
Lee_edwards
The TPS loosing signal turned out to be a faulty TPS
