Firmware development toolchain details
What tool chain is being used to develop the firmware for RCP?
Thanks!brentp wrote:We're using http://www.gnuarm.com/
Will do.brentp wrote:Keep us posted on the work you're doing!
I constructed a temporary dash that interfaces directly to a Hondata ecu, while I waited for the RCP BT/Android solution. Now that's here it's time to look at getting up to speed with the firmware and inserting the RCP into the picture
![Smile :)](./images/smilies/icon_smile.gif)
My initial plan is to commandeer the telemetry port but I'm interested to understand what the Y-cable serial adapter project looks like as far as sharing the port. Are you planning on using a higher level transport protocol to allow some sort of device addressing scheme?brentp wrote:Are you looking to interface via one of the serial ports?
btw. I was able to install the toolchain frontend with eclipse and get a clean build. thx for the heads up
I bring this thread up again.
I bought the MK2 yesterday an waiting. For my car setup i have to do several thing to fit my needs.
First is to get the Custom PID for Oil Temperature (Toyota GT86). For that i need to modify the current firmware. Are there some documentation for a kickstart? Which tools i need and where the debug/programming interface is? Do i program over USB?
The second thing (for me more easy) the external communication over bluetooth or USB. Is there any protocol documentation.
I need that ready by middle of march.
Hope you could help me.![Smile :)](./images/smilies/icon_smile.gif)
A sticky poste about that would be helpful.
Toolchain documentation is here with the repo:
https://github.com/autosportlabs/RaceCa ... o_firmware
Do you have documentation on the extended Toyota PIDs? We'd like to capture that information in the wiki, if possible.
We also have a project to document the serial API. coming soon!
Relates to: http://www.ft86club.com/forums/showpost ... ostcount=2
OIL
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0 (Auto also works, but seems to take longer)
PID: 2129
Long name: Fuel Remain (or whatever you want)
Short name: Fuel Remain (or whatever you want)
Minimum Value: 0.0
Maximum Value: 100.0
scale: x1
Unit: Gal
Equation: ((A*13.2)/100)
OBD Header: 7c0
If you want the fuel remaining in Liters:
Unit: L
Equation: ((A*50)/100)
Custom PIDs the MK2 has not supported yet, right? I've seen this part of source code. This was one point why i bought that. Seems to be good stuff. So i need a stm32 program adapter?! I think, i have to look how to develop for a stm32 in general.
In the past i develop more Atmel and currently all the time C++/Qt.
OT: Hope my board is coming soon. Will it take long to come to germany?
OIL
Minimum Value: -40
Scale factor: x1
Unit type: C
PID: 2129
Minimum Value: 0.0
scale: x1
Unit: Gal
OBD Header: 7c0
Unit: L
Thank you for the information. I think a way to specify custom OBD-II PIDs would be a good addition to the system. Currently we offer the standard PIDs, which are easiest, but custom PIDs could be supported as well.
You don't need a special programmer; you can compile the firmware and then upload it the regular way over USB.
Shipping to germany is about 6-10 days, typically, once it is shipped.
Yes the source code look pretty clean. Maybe something like a factory construction for every supported car could be good. But a i have a big question. Your box support ODB2 over CAN. Currently i have my smartphone with a bluetooth based ELM327. So with your box i do not need any ELM327 anymore, right?
Exactly, you don't need the ELM327 bluetooth module; the Bluetooth will plug right into the CAN OBD-II port of the car.
We have a cable that will provide data and power to the RCP, here: http://www.autosportlabs.com/product/ca ... -ii-cable/
