Fuel level sample rate
PopKorn78
Post by PopKorn78 »
Hello again,
I was just wondering if there is a way to get a higher sample rate then 1hz? The fuel level is reacting to fast to the fuel slushing around. A sample rate of 0.1hz would be just fine for what I need. I'm not that familiar with script, but I will do learning on Google this evening.
The best way to deal with fuel slosh is to use a filter on that channel, which will more-or-less average out the sloshing in the tank.
We have filtering enabled in the firmware, but it's not yet exposed through the user interface. The filter will have an adjustable dampening figure. Not sure if it'll make it into the 1.2.5 app, but it will be out soon!
