RPM signal
RPM signal
Hi guys,
I'm trying to get a RPM signal for my RCP. The car is a Civic with a B16 engine with a distributor. What wire should I get the signal from?
I have a CoilX on hand if needed.
- image.jpg (61.21 KiB) Viewed 11628 times
- image.jpg (27.26 KiB) Viewed 11628 times
Thanks Brent,
First, I had the wrong distributor wiring.
I have tried with the YEL/GRN and BLU, but RCP reads 0. On both test, I had the coilX installed. I tried the BLU test straight without the CoilX, but no change.
I have a tach tap in the BLU that works fine.
Voltage on both wires is 10.5v, there is no peaks that I can see on the multimeter, I don't have a scope yet.
Should I try to get to the WHT/BLU from the COIL to the ICM in the distributor on the negative?
- Inside Dist.png (122.29 KiB) Viewed 11592 times
- Distributor.png (39.83 KiB) Viewed 11597 times
Still no luck. I had the OBDII RPM channel enabled. I removed it and redid all the wires again, with and without CoilX, but no signal again.
I'm waiting for a scope to try to help you so we can figure this out, but if you have any other idea to try, let me know please.
Here are some links that might help you out.
http://www.diyautotune.com/tech_article ... _acura.htm
https://www.hondata.com/forum/viewtopic.php?t=7759
http://www.team-integra.net/forum/17-au ... butor.html
Good news, I found the signal, it's from the yellow/green wire from the distributor set to 2 pulse per rev. It worked after I flashed the firmware to reset the RCP. It looks like eventho I disabled the OBDII channel, it was still blocking it.
But I have another issue. I have a reading in the raw page of the dashboard on RPM2, but on the analog page, I get nothing. It did worked the first time, but when I cam back to the car after 1h, the RCP App had shutdown on my pc and since then, nothing.
Forget what I've posted ealier, I was so exited that the RPM worked, the I've set the low and high limit at the same ragne.
The only clarification I would like is about the reading I get when the car is not running. Does it matter? I thought it might be voltage peaks, so I tried with the CoilX, but I don't get any reading.
When this is all sorted out, I will make a post for the Honda guys with the how to's so that another noob like me does not have to make you go crazy with lame questions
