Aem wideband calibration
Derrick@art
Post by Derrick@art »
Im trying to calibrate our wideband so it reads the same as the gauge on the sofware. and i cant seem to get it to work correctly. has anyone here done this before or can can anyone give me some insight on doing so.
This is the gauge we have and here are the instructions for it.
http://aemelectronics.com/files/instruc ... 0Gauge.pdf
Also i would like to hookup water temp to the race capture pro just wondering if I can tap off the stock mazda ecu temp sender?
Thanks in advance
momostallion
Post by momostallion »
I have my AEM wideband setup on my RCP unit.
I used the analog 0-5v white wire out of the AEM, connected it to one of the 7 analog inputs.
In RaceCapture's configuration, I set :
Channel Name: AFR
Sample Rate: 25hz
Mode: Mapped
for mapped, use 5 points of calibration. using your aem instructions for gasoline AFR, i would use:
0.0 0.94 1.87 2.96 4.05
10.0 12.18 13.74 15.92 18.10
that should do it.
momostallion
if you tap off an ecu sensor, just test it with a multimeter first and make sure it's a 5v analog signal then simply connect it to another analog input.
you will have to scale it yourself however. i've done this as well. simply use a known value (read your temperature gauge at it's maximum range, hopefully it has a digital read out). build your own scale using 5 different voltage readings and temperatures and set that input's channel name to Coolant. wouldnt need more than 1Hz for coolant IMO.
also you could consider using CANBUS data from your OBD2 port. ECT is something that will be available.
Derrick@art
Thanks alot for the response i will try what you suggested and see if that works for me.
