Hi all,
Plan on ordering a RCP 2 soon for my track car, question is, when I upgrade to a Haltech Elite 1500 ecu later in the year, will I be able to capture CAN data from it to the RCP 2?
Obviously I also want to stream this CAN data to the RCP android app.
Cheers!
Haltech Elite CAN data streaming to RCP 2?
I have a LUA script that works with the Haltech ECUs via the Haltech CAN v2 protocol. I've only tested it on my PS1000 but it should work on any of the later ECUs including the Elite.
I'll polish it up a bit and send it to the guys to post on the wiki. So far I've gotten around 11 CAN streams to work including: TPS, MAP, AIT, Coolant Temp, Oil Temp, Oil Pressure, Fuel Pressure, Fuel Temp, Fuel Composition, RPM and Injector duty Cycle. There are many more that can be hooked up easily if required.
Cool, can you send it through to me so I have have a squiz? I'll PM you my email address.
I have the full Haltech V2 CAN Protocol document. It would be good to know if the Elite is the same as the PS2000 / PS1000 ECUs. I suspect the base CAN is the same, with maybe some additional data in the reserved areas.
Also, shout out if you need any help with the scripting. I have the CAN side sorted now so it would be easy for me to modify or add new channels if required.
