RCP MKII Unable to locate bootloader -Firmwar not uploading
Moderators: JeffC, stieg
Hi Danny,
Could you try using the latest 1.3.13 software? We just released it last night.
Once you install it, try performing the installation. If that fails, immediately go to the System Status page and click application status (first menu item) then click the button to copy the application log to the clipboard. Paste that here.
It's important you grab the application log immediately after failing the upgrade so we can catch what it's doing in the act; recommend you find the place where you can grab the app log first before attempting the firmware upgrade.
Side note, were you ever able to update firmware in the past?
danny325is
Post by danny325is »
Brent,
I was able to do it in the past on Windows 7. I have never been able to do it on Windows 10. I have added the unsigned driver and all.
I will try the new app tonight. i will copy and paste what I can.
I am also have a problem of telemetry over Wifi that I posted here http://www.autosportlabs.org/viewtopic.php?t=4596
Hi Danny,
Thanks, we'll watch for the update. We'll work to double check it on windows 10 as well.
danny325is
Ok attached are the logs from the primary method and alt motherd plus the atl method do a full restart of the app
I have turned off anitvirus
I have tried diffrent cables
I have tried from USB2 and USB3 ports
rcp primary method.txt
(5.88 KiB) Downloaded 429 times
rcp alt method.txt
(7.02 KiB) Downloaded 644 times
rc alt methed full restart.txt
(6.32 KiB) Downloaded 492 times
danny325is
i also randomly get this message.
Hi Danny,
Thanks. So these were logs immediately after trying to do the firmware upgrade. I don't see anything in the logs about it trying to actually do the firmware upgrade process, which is interesting.
Can you try an older version of the app, say 1.3.0 ? Got a MacOS computer you can try with?
http://www.race-capture.com/software
In the meantime, we're going to try some additional things for you to test - seems like maybe the normal communications process is trying to compete with the firmware upgrade process.
Thanks, This provides some clues. We'll get on this.
Also: the 0.0.0 warning message is harmless and pops up periodically. On our list as well.
danny325is
I don't have a mac. I might have a windows Xp or 7 machine in a closet somewhere.
I have Linux machines, but that dosen't help.
I will try an older version this weekend. I will also take the RCP out of the race car so i can do testing easier.
danny325is
1.3.0 didn't work. Running as admin didn't work.
tried 1.3.13 again didn't work
[RCPAPI ] Giving up on COM14
[RCPAPI ] Did not find device
[RCPAPI ] auto detect finished. port=None
[RCPAPI ] Message rx worker exception: None | <type 'exceptions.Exception'>
[RCPAPI ] Starting auto-detect
[RCPAPI ] Searching for device on all ports
[RCPAPI ] Too many Rx exceptions; re-opening connection
[RCPAPI ] attempting to recover connection
[RCPAPI ] Trying COM14
[Comms ] Opening connection COM14
[RCPAPI ] Found device version 0.0.0 (s/n# 0) on port: COM14
<kivy.uix.gridlayout.GridLayout object at 0x071F59D0> have no cols or rows set, layout is not triggered.
[RCPAPI ] auto detect finished. port=COM14
[RCPAPI ] Found device version RCP_MK2 2.8.2 (s/n# 004A00333034511830393933) on port: COM14
[DataBusPump ] DataBus Sampler Starting
[StatusPump ] starting
[RCPAPI ] Execute Sequence begin
[RcpConfig ] Config version 2.8.2 Loaded
[RCPAPI ] Execute Sequence complete
[DataBusPump ] Synchronous sampling mode enabled
[DataBusPump ] Sample Meta is stale, requesting meta
[RCPAPI ] sending meta
[RCPAPI ] Message rx worker exception: 0,10.1,240.0,0.05279,4.74,-0.12,-0.17,0.87,-58.6,-59.1,-54.4,0,0.0,0.0,0.0,0.0,0.0,0,0,0.0,0,0.0,-1,0.0,0.0,0.0,0,268435455]}} | <type 'exceptions.Exception'>
[RCPAPI ] Disabling auto recover
<kivy.uix.gridlayout.GridLayout object at 0x0939CCA8> have no cols or rows set, layout is not triggered.
stderr: Exception ValueError: 'could not convert string to float: ' in 'kivy.properties.dpi2px' ignored
danny325is
Ok good news...sorta. I used my last remaining non-windows 10 machine my HTPC and I was about to update the firmware.
