Compile MK2 firmware
mach1000
Post by mach1000 »
Hi guys,
I have been trying to learn about the whole compile process but havent got it running. I will admit that I am a rookie with regards to compiling so maybe thats the reason.
I am running a ubuntu 14.04 desktop and been following the steps from github.
I have added path variables to my bashrc file.
I have attached a txt with output from commands.
Please let me know if something is reallly screwed up!
Thank you!
compile_asl.txt
(19.99 KiB) Downloaded 656 times
Is this what you're specifically referring to?
arm-none-eabi-gcc: error: nano.specs: No such file or directory
Also note, you shouldn't need to execute make with sudo.
mach1000
Post by mach1000 »
Yes as I can see through the output that is the main error for not compiling. Am I missing a package or maybe a path?
I am sorry for my ignorance but there is only way to gain knowledge :)
mach1000
Post by mach1000 »
Got it all working, I deleted my path's and started all over - that corrected the error :)
