RCP2 failing with no usage, Amazon app
Have a fast flashing error light on a new RCP2 device. Initially setup with a Mac with 1.3.13, flashed to firmware 2.8.5 with no issues. Loaded tracks, made configuration changes, tested OBD2 in car, tested GPS in car...all good. Shelf for 1 week, power up and rapid flashing error. Changes= added Bluetooth telemetry module, added Amazon Fire to mix with app from Amazon store, connected RCP2 to bluetooth and solid green on bluetooth adapter. (BTW if we get this working OMG its going to be perfect when analysis goes live...no more laptops at the track and the Amazon fire at $50 is easily replaceable commodity hardware, perfect for the track)
Tried resetting with power on and holding log button, no luck. Device is dead and non responsive.
Plugged RCP2 back into the Mac wi OS X 10.10.5, open Race Capture app...searching, searching searching....help. I really hope this is a fluke and not the norm with the hardware, I love what you guys are doing...
Hi Katmeho,
When you say 'rapid flashing error' are you saying the RCP is flashing the red LED rapidly and continuously? Similar to the bootloader mode when you hold down the button and plug it in?
Try this:
Try using the app to flash new firmware again and see if it takes. If it does not start up normally (e.g. you can connect via desktop) try this:
Flash to an older 2.7.x firmware https://autosportlabs-software.s3-us-we ... _2.7.9.zip
Then flash back to latest firmware: https://autosportlabs-software.s3-us-we ... _2.8.5.zip
Bouncing between 2.7.x and 2.8.x will trigger a factory configuration reset.
Let us know what you find out. Thanks!
Try this:
The last time I ran the update it got to 100% but then said it couldn't validate the flash. 3 other times it never made it to 100%.
The device today has been connected only to USB. But before I started having failures, I did have it connected via the OBD2 port (which is 12v right?) That was the last time it worked.
