E46 Individual Wheels speeds and other channels
I thought this would be a good place to share this info. I have individual wheel speeds, clutch and brake indicator along with a couple of other channels deciphered. These work for my M3, I'm assuming they will work for all 3-series but this would need to be verified.
wheelLFId = addChannel("Wheel_LF", 10, 1, 0, 180, 'MPH')
wheelRFId = addChannel("Wheel_RF", 10, 1, 0, 180, 'MPH')
wheelLRId = addChannel("Wheel_LR", 10, 1, 0, 180, 'MPH')
wheelRRId = addChannel("Wheel_RR", 10, 1, 0, 180, 'MPH')
clutchId = addChannel("Clutch", 10, 0, 0, 1)
brakeId = addChannel("Brake", 10, 0, 0, 1)
fuelId = addChannel("FuelLevel", 1, 1, 0, 70, 'ltrs')
ambTempId = addChannel("AmbTemp", 1, 0, 0, 60, 'C')
ambPresId = addChannel("AmbPress",1, 0, 970, 1030, 'mBar')
--Remove erroneous readings from wheel speed
function wheelFilter(value)
if value > 3583 then value = value - 3584
elseif value > 3071 then value = value - 3072
elseif value > 2559 then value = value - 2560
elseif value > 2047 then value = value - 2048
elseif value > 1535 then value = value - 1536
elseif value > 1023 then value = value - 1024
elseif value > 511 then value = value - 512 end
return value * 0.621
end
[339] = function(data) map_chan(brakeId, data, 0, 1, 0.0625, 0) end,
[496] = function(data) map_chan_le(wheelLFId, data, 0, 2, 0.0625, -8, wheelFilter) map_chan_le(wheelRFId, data, 2, 2, 0.0625, -8, wheelFilter) map_chan_le(wheelLRId, data, 4, 2, 0.0625, -8, wheelFilter) map_chan_le(wheelRRId, data, 6, 2, 0.0625, -8, wheelFilter) end,
[809] = function(data) map_chan(ambPresId, data, 2, 1, 2, 298.5) map_chan(clutchId, data, 3, 1, 1, -20) end,
[1349] = function(data) map_chan(oilTempId, data, 4, 1, 0.8117, -48) end,
[1555] = function(data) map_chan(fuelId, data, 2, 1, 1, 0) end,
[1557] = function(data) map_chan(ambTempId, data, 3, 1, 1, 0) end,
end
Thanks for sharing! Very clever using the filter function to clear out the extraneous bits. Do you also have it combined with the original script from here? http://autosportlabs.net/BMW_E46_CAN We recently added steering angle to the channels.
The ride height sensors are on the left side front and rear. It should be reasonable simple to add additional ones to the right side though. From what I've read, no data is available over the CAN bus from the light control module. The module does have the can bus wires running to it but I believe that is because it stores mileage, VIN and vehicle order as backup the the instrument cluster.
I have a mk60 ABS system from the E46 M3 in my car, and have CAN bus messages activated and broadcast.. I am going to give your script a try over the weekend - I have removed things like oil temp and TPS as I have a standalone ECU for the engine which doesn't output this data unfortunately
Given you have steer angle, wheel speeds, brake activation, etc working, I wondered if anyone has been able to read the brake pressure sensors (F / R) in the ABS system as well?
I did a search and can't see any reference to it anywhere...
The 2.8.7 release here: https://www.autosportlabs.com/2-8-7-fir ... has-moved/
includes support for bitOp, which means it'll be much easier to extract certain E46 data that spans un-even byte boundaries, like fuel level and individual wheel speeds.
From what I understand, brake pressure is not consistently available on all cars; it depends on how the car is optioned.
ok thanks will take a look
my car isn't actually an e46 but it has the e46 m3 (mk60 teves) abs system with m-track enabled, can emulator, yaw sensor, steer sensor, etc, etc..
hopefully will be getting the unit reprogrammed soon for the full motorsport software which might make it easier to pull things like this off the CAN network too
Here's an experiemental script that enables 15 channels from the E46 CAN bus leveraging the new capabilities of the 2.8.7 firmware.
It's completely untested; and as I don't have an E46 I can only simulate the data by using a 2nd RCP.
https://gist.github.com/brentpicasso/98 ... 066b82c92e
Note, some channels may not have data depending on the specific E46 platform. Brake pressure seems to be one that's commonly missing. Note the script enables the brake switch, separate from brake pressure.
If you have a chance to test it let me know; be forewarned, it could work perfectly or be completely broken. But if you do test it let us know what does work.
Very new to lua scripting (like this is my first time doing ANYTHING)
Can anyone comment on this modification?.. Will this give me degrees C rather than F? And do my min/max values have to be exactly the same as before (converted values) or is "near enough = good enough)
--format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units])
tpsId = addChannel("TPS", 10, 0, 0, 100, "%")
tempId = addChannel("EngineTemp", 1, 0, -18, 125, "C")
oilTempId = addChannel("OilTemp", 1, 0, -18, 125, "C")
rpmId = addChannel("RPM", 10, 0, 0, 10000)
steerId = addChannel("Steering", 10, 0, -360, 360, "Deg.")
brakeId = addChannel("BrakeSw", 10, 0, 0, 1)
brakePressId = addChannel("Brake", 10, 0, 0, 255, "Bar")
lfWheelId = addChannel("LFWheelSpd", 10, 0, 0, 200, "MPH")
rfWheelId = addChannel("RFWheelSpd", 10, 0, 0, 200, "MPH")
lrWheelId = addChannel("LRWheelSpd", 10, 0, 0, 200, "MPH")
rrWheelId = addChannel("RRWheelSpd", 10, 0, 0, 200, "MPH")
gearTempId = addChannel("GearboxTmp", 10, 0, 0, 205, "C")
fuelId = addChannel("Fuel", 1, 0, 0, 100, "%")
extTempId = addChannel("ExtTemp", 1, 0, -18, 50,"C")
--Convert C to F
--function toF(value)
--return value * 1.8 + 32
end
--Convert C to F
end
first, note we've announced the extended E46 channels here:
https://www.autosportlabs.com/help-us-t ... -channels/
To not perform the C to F conversion, you can remove the "toF" reference in the mapping.
See line 107, 110 and 111 here in the current script:
you would just remove the part of the line that is
, toF
(remove the comma and the "toF" portion)
so, line 107 looks like this - see how the ", toF" is missing?
map_chan(tempId, data, 1, 1, 0.75, -48 )
Alternatively, you can modify the "toF" function to not do the conversion.
You can do this starting on line 29
--Convert C to F
function toF(value)
return value
end
You can see how it returns just the value without performing any conversion.
Hope this helps - please report back on your findings.
, toF
--Convert C to F
function toF(value)
return value
end
Awesome thanks - I'm really new to any kind of programming but use excel a lot - this seems like a half way house so looking forward to playing!
I've not really tested yet but at first glance I don't think I can see brake pressure values on a car with mk60 abs (conti-teves from m3 e46) but I was under the impression that the brake pressure values are not transmitted via CAN on this system anyway.. My car isn't the definitive answer though as its standalone abs / DSc in an e36..
