RaceCapture and aftermarket wideband O2 sensors
Does the new RaceCapture support aftermarket wideband O2 sensors? Eg. Innovate LC-1, AEM UEGO, PLX, etc. ?
2006 Subaru WRX
The sensor is typically a Bosch or NTK sensor. What you are mentioning is the controller for the sensor. If you're asking if the RaceCapture supports them, as long as they have an analog output, which most of them do then yes, it is supported. You would hook up the analog output of the wideband controller to one of the analog input of the RCP and then configure the analog input using the application.
I'm referring to the new kickstarter RaceCapture since I didn't see any ports for it.gizmodo wrote:The sensor is typically a Bosch or NTK sensor. What you are mentioning is the controller for the sensor. If you're asking if the RaceCapture supports them, as long as they have an analog output, which most of them do then yes, it is supported. You would hook up the analog output of the wideband controller to one of the analog input of the RCP and then configure the analog input using the application.
2006 Subaru WRX
