The BT LED is tied right into the BT module itself. the BT module controls the flashing pattern - flashing when not paired, solid when paired.
Also - having the ability to select / lock-in and override the BT name is on the list as well, but auto-detection is the way it'll work initially to have a "just works" experience that minimizes user intervention and steps.
MK1 can't connect to android app
Hey guys, I don't think I ever got a response... Solostorm connects to the RCP just fine, but the RCP app just won't, regardless of how long it sits and spins at "connecting".murph1379 wrote:The Racecapture app is version 1.3.13, according to Android.brentp wrote:Hi - let's figure this out more.
Are you running the 1.3.7 app or did you sign up for the 1.4.3 beta ?
What tablet make / model are you using?
Do you see this problem on another android device, just as a comparison?
It's a Samsung Galaxy Tab 3 7", 2013 model running Android 4.4.2.
I don't own another Android device, so I haven't been able to test that.
Any ideas? Can I pull some more data for you somehow?
Thanks for following up.
Looks like you're on the 1.3.13 app - could you by chance try the 1.4.4 we have in beta? That would be a good comparison.
https://groups.google.com/forum/#!topic ... rFwAW08CZM
If you're not in the beta already you can opt in here:
https://play.google.com/apps/testing/co ... acecapture
-Brent
-Brent
Thanks for the quick response, I'll see how that goes once I get approved for the group.brentp wrote:Hi,
-Brent
ok, tried the beta, interesting results... I can see it search linvor, which is the RCP, and the RCP bluetooth light turns solid green indicating it's paired, and the little icon that indicates the app is reading data lights up, but the app still keeps moving and eventually gives me an error dialog box "Could not read configuration:"brentp wrote:Hi,
-Brent
Interesting on the Linvor. The firmware should be renaming the bluetooth module to RaceCapturePro.
What firmware version are you running on MK1?
Could you run from the desktop, do a fresh power up and then view the app log file under the scripting window? This will have some information about it trying to manage the BT module.
Also, can you email your current configuration to us? racecapture@autosportlabs.com.
Hi Matt,
Thanks. I looked at your config and it seems sane.
A couple of things to try.
* can you test with the 1.4.5 app we just released in google play beta? We have some changes in there that might improve communications with MK1
* as an experiment, can you try a different android device? I understand you're able to communicate with Solostorm, but this is just a diagnostic measure.
Thanks - will watch for an update.
Yes, most of the configuration screens are very slow.brentp wrote:Thanks for the update, and glad it's working for you.
Are you talking about the configuration screen? what device are you using?
The configuration screens will receive updating as we blend in the work from the Kickstarter, and in the process we'll see some performance improvements.
Im using a samsung galaxy 7" tablet running Android 4.4.2
