First of all - I can say with some pride that I've now been running my Megajolt for almost 10 years on this car! It's been so reliable that I haven't had to give it much thought over the years.
My MJLT v3 is on firmware 3.2.1 - originally I ran it with a Weber DGV down-draft carb, and built it for MAP. Later on I converted it to TPS by adding the extra components and cutting R4 (270R) to isolate the MAP sensor.
Now I want to go back to MAP, having decided to ditch the bike carbs and go back to a single Weber DGV. Can I just replace R4 to use the MAP sensor? The TPS wiring will be disconnected, of course. I've looked at the schematic and I can't see that the TPS components will have any effect on the MAP signal - am I right?
Many thanks,
David
