OBD-II to CAN-bus Cable, Active or Passive?
JJLudemann
Post by JJLudemann »
I'm trying to connect my RaceCapture Pro Mk.2 to the ECU on my 2007-2008 Suzuki GSX-R1000-engined race car. There is no OBD-II connector, just an undocumented connector that the Internet has figured out supports the K-line subset of OBD-II. I have the CAN-bus to OBD-II cable from Autosportlabs, but I need to know:
1) Is it just a passive electrical connection from the RJ-11 RaceCapture Pro connector to the CAN-Hi and CAN-Lo ISO 15765-4,
OR
2) Does it have an OBD-II chip in it that supports various OBD-II protocols, in particular the K-line ISO 9141-2.
If it is only a passive connection, I figure I can instead connect the RaceCapture Pro CAN-bus connetor to a CAN-bus to serial adapter in series with a serial to ISO 9141-2 adapter and retain software compatibility, i.e. don't have to write all my own Lua scripts to interrogate the ECU.
Any ideas on if any of this will work? I remember Brent recently saying he's developing ISO 9141-2 support, which implies none of this will currently work. Brent, do you need a beta tester?
-JJ
LudemannEngineering.com
Sorry for the late reply.
The CAN connections on RaceCapture/Pro is simply a CAN bus connection to the OBD-II port, so it will require a CAN enabled OBD-II ECU.
Hope this helps!
