Connection cable between controller and computer
robert verhey
Post by robert verhey »
My Megajolt Lite Jr has a 9 pin outlet for connection to the computer. What to do now that my new computer has no 9 pin connection anymore? Only 15 pin, USB and other "flat connectors". Are there adaption cables, or?
Otherwise 0 problems with my 8 year old Megajolt!
Robert Verhey
Sounds like a version 3 controller, with the 9 pin plug on the enclosure? In which case, that's a standard 9 pin serial connection. You can use a USB to Serial cable which will have the correct cable connection.
Let us know if you're still stuck and we can provide links for you.
SpitMan
Comms problems
Post by SpitMan »
Hello,
I am now at the point of hooking up my computer to my Megajolt. I finally got MS to acknowledge the port but now having problems trying to communicate with the MJolt. The errors are: Time out occurred and Communications Time Out occurred.
Question: My computer only has USB connections, so, do I need a smart USB cable (one with a chip in it) or make a direct wire USB to the RJ-11 jack?
I have the DB9 to RJ-ll adapter I purchased from you but need to convert to USB.
If I must make the cable or buy a direct connect cable like the one you offer, is there a software driver available?
If it is a direct connect, what is the data rate and other parameters used on the Mjolt serial port??
Doug
brentp wrote:Sounds like a version 3 controller, with the 9 pin plug on the enclosure? In which case, that's a standard 9 pin serial connection. You can use a USB to Serial cable which will have the correct cable connection.
You will need a USB to serial adapter to go between your computer and the RJ11 cable we provide.
https://wiki.autosportlabs.com/MJLJ_V4_ ... erial_Port
A good quality unit is recommended - you can find them on Amazon or we have one in our online store: https://www.autosportlabs.com/product/c ... l-adapter/
SpitMan
Post by SpitMan »
Brent,
Regarding your USB adapter, does it come with driver software?
Doug
brentp wrote:Hi,
Hi Doug,
Windows will likely detect it automatically. If it doesn't, the included drivers can be used.
robert verhey
Hi Brent,
Thanks for the info. I will put the Autosport Labs USB/9pin connector on my wish list for Christmas.
The version 3 system on my 1952 Willys Jeep is still functioning very well - without a hitch during the last 8 years or so since I installed it.
Best regards, Robert
