Can't connect to Race Capture after trying to use hot spot
Moderators: JeffC, stieg
lamfalus
Post by lamfalus »
I setup my new race capture to try and connect to my phone's hot spot but it never connected and now it's also not broadcasting its own SSID. I seem to have gotten into a state where because it won't connect to the hot spot I can't re-enable the SSID either. Is there a way to reset the Race Capture settings?
lamfalus
Post by lamfalus »
Never mind, I realize now you can connect over USB as well. Was able to use the PC based app to re-enable the wifi.
Glad you figured it out. USB is always the fail-safe for resetting configuration.
