I've updated my Lua script to include:
startLogging()
I've verified that the system is "logging" under the System Status menu. However, no logs are produced. If I connect my laptop, access the app, and go to the dashboard, logging starts. This is the only way for me to get a log. The RCP3 can write to the microSD card just fine.
RCP3 Only logs data in Dashboard mode
Correct.
The startLogging() in the Lua script runs in the context of RCP and controls the SD card logging behavior. It's worth noting that RCP is designed to run autonomously, not requiring a display for operation - once you set it up, it runs on it's own as a data acquisition system / telemetry device.
The in-app logging was added later for additional convenience.
Hope that helps!
Hope that helps!
I was trying to figure this out today as well.
Say i just cruise around the streets, dashboard mode, logging on. I then go to Analysis mode and i can see sessions saved, but i can't view plots of any of the data. I think this is because there are no laps since i wasn't on track?
I would like to simply scroll through the selected data channels for the duration of the session log, is this possible?
I'm also confused about logging to the dashboard tablet vs logging to the RCP SDcard. Do they both start with startLogging() and stop with stopLogging()? When i'm in analysis mode, am i looking only at the data saved on the tablet? Is the data on the SDcard only for review on a computer later, not on the tablet? In the preferences, there is an option to turn off logging on the tablet. If i do this, can i still review data from the SDcard on the tablet?
I'll try to expand on what I explained earlier in the thread.
In the long long ago, RCP only logged via SD card. More recently, with the introduction of RaceCapture/Track, we added in-app logging as a convenience for having immediate data available for analysis. It's a natural enhancement of the system and now augments the existing SD logging capabilities, which is primarily geared towards logging data as an autonomous, headless 'black box' data logger / telemetry system.
The Lua script commands run in the context of RCP and only controls SD card logging; it does not affect the logging behavior of any client consuming the telemetry stream. The API doc has been clarified here:
https://wiki.autosportlabs.com/RaceCapt ... ng_control
Regardless if the data is logged via SD card, or on-the-fly in the app, it's simply the same data.
Both approaches will record laps if lap timing is active, or just a single session of data without laps, where a span of data can be viewed.
An example of recording some static data on the bench and immediately viewing it. You can try it right now:
https://www.youtube.com/watch?v=tA1jWfrmEog
With SD logging, you have to pull the SD card, then manually import the data into analysis.
As before, in both approaches, you reach the same destination with effectively the same data.
Hope this helps!
Hope this helps!
