Lua Script Delay Function
Moderators: JeffC, stieg
boggie1688
Post by boggie1688 »
My new project for the RCP3 is to get the GoPro script nice and polished.
The script provided in the wiki is great! Thank you to the author!
I was trying to spruce up the script a bit more, but having it set the following:
1. Switch to camera mode
2. Set orientation to up
3. Set desired resolution
4. Set desired Field of View
This way, I don't have to remember to setup the camera before hand.
It was easy enough to create functions for each of those camera settings, however I think the script is executing too quickly. It fires commands rapidly at the GoPro, and while the first command is recognized, I think the subsequent ones are missed.
Is there a way to have the Lua script delay a given number of seconds after firing the first command?
Try the sleep(ms) command - this will stall the lua script for the specified time.
Great on the GoPro script!
We're working to implement this capability in the firmware. Need to check again but, is 'switch to camera mode' the command that some of the newer GoPro's need to enable remote control? This will be one of the things we need to do (I believe) when we implement it in the official firmware.
boggie1688
Brent,
I have a GoPro Hero3, not sure about the newer units.
I was using the camera mode to make sure that the GoPro switches to video recording and not photo/time lapse burst. I could have used the GoPro between Autox events, and want to make sure that I don't take a photo when I'm actually trying to record a video.
I'll post a copy of what I put together when I finish.
boggie1688
setTickRate(50)
function onTick()
checkGoPro()
getSteering(1)
if getGpsSpeed() >= 1 then
startLogging()
end
end
steerId = addChannel("Steering", 50, 0, -450, 450, "Deg.")
function getSteering(chan)
id, ext, data = rxCAN(chan,100)
if id == 194 then
processSteering(data)
end
end
function processSteering(data)
local steer = 0
if data[2] < 128 then
steer = -1*((data[2]*256)+data[1])
else
steer = (((data[2]-128)*256)+data[1])
end
setChannel(steerId, (steer*.0436))
end
--Specify your GoPro wifi password here
goproPwd = "blahblah"
--Specify your GoPro SSID here
goproSsid = "RCP3WIFI"
--Speed threshold to start recording
goproStart = 5
--Speed threshold to stop recording
goproStop = 1
--How fast we check, in Hz
tickRate = 10
--Set this to 1 to log communications between RCP & WiFi
debug = 1
--DO NOT EDIT BELOW
--the serial port where the WiFi is connected
port = 4
--indicates wifiStatus
--0 = not init, 1 = init sent, 2 = got IP, 3 = ready
wifiStatus = 0
lastInitTime = 0
initTimeout = 20000
function logMsg(msg)
println('[GoProWiFi] ' ..msg)
end
function sendCrlf()
writeCSer(port, 13)
writeCSer(port, 10)
end
function sendRaw(val)
for i=1, #val do
local c = string.sub(val, i, i)
writeCSer(port, string.byte(c))
end
end
function sendAt(val)
if debug == 1 then logMsg('send: ' ..val) end
sendRaw(val)
sendCrlf()
end
function toInt(val)
return string.sub(val, 1, -3)
end
function httpGet(url)
sendAt('AT+CIPSTART="TCP","10.5.5.9",80')
sleep(500)
local crlf = string.char(13) ..string.char(10)
local get = 'GET ' ..url ..' HTTP/1.0' ..crlf ..crlf
sendAt('AT+CIPSEND=' ..toInt(#get))
sleep(100)
sendRaw(get)
sleep(100)
sendAt("AT+CIPCLOSE")
end
function sendGoProShutter(cmd)
httpGet('/bacpac/SH?t=' ..goproPwd ..'&p=%' ..cmd)
end
function startGoPro()
logMsg('start GoPro')
sendGoProShutter('01')
end
function stopGoPro()
logMsg('stop GoPro')
sendGoProShutter('00')
end
function initWiFi()
logMsg('initializing')
sendAt('AT+RST')
sleep(2000)
sendAt('AT+CWMODE_CUR=1')
sleep(1000)
sendAt('AT+CWJAP_CUR="' ..goproSsid ..'","' ..goproPwd ..'"')
wifiStatus = 1
end
function processIncoming()
local line = readSer(port, 100)
if line ~= '' and debug == 1 then print(line) end
if string.match(line, 'WIFI GOT IP') then
wifiStatus = 2
end
if wifiStatus == 2 and string.match(line, 'OK') then
wifiStatus = 3
sleep(2000)
if power == nil then
power = 0
end
if power == 0 then
logMsg('Powering up GoPro')
sleep(2000)
sendPowerUp('01')
sleep(1000)
logMsg('GoPro On')
power = 1
end
if cameramode == nil then
cameramode = 0
end
if cameramode == 0 then
logMsg('Switching to Camera Mode')
sleep(1000)
modeCameraGoPro('00')
sleep(1000)
logMsg('Camera Mode Set')
cameramode = 1
end
if orientation == nil then
orientation = 0
end
if orientation == 0 then
logMsg('Setting Orientation Up')
sleep(1000)
orientationupGoPro('00')
sleep(1000)
logMsg('Orientation is Up')
orientation = 1
end
if resolution == nil then
resolution = 0
end
if resolution == 0 then
logMsg('Setting Resolution')
sleep(1000)
setresolGoPro('06')
sleep(1000)
logMsg('Resolution Set')
resolution = 1
end
if fov == nil then
fov = 0
end
if fov == 0 then
logMsg('Setting FOV')
sleep(1000)
setfovGoPro('01')
sleep(1000)
logMsg('FOV Set')
fov = 1
end
end
end
function sendPowerUp(cmd)
httpGet('/bacpac/PW?t=' ..goproPwd ..'&p=%' ..cmd)
end
function modeCameraGoPro(cmd)
httpGet('/camera/CM?t=' ..goproPwd ..'&p=%' ..cmd)
end
function orientationupGoPro(cmd)
httpGet('/camera/UP?t=' ..goproPwd ..'&p=%' ..cmd)
end
function setresolGoPro(cmd)
httpGet('/camera/VR?t=' ..goproPwd ..'&p=%' ..cmd)
end
function setfovGoPro(cmd)
httpGet('/camera/FV?t=' ..goproPwd ..'&p=%' ..cmd)
end
function checkGoPro()
if wifiStatus == 0 then
initWiFi()
lastInitTime = getUptime()
return
end
if wifiStatus == 1 and getUptime() > lastInitTime + initTimeout then
logMsg('could not connect to GoPro')
wifiStatus = 0
end
processIncoming()
if wifiStatus ~= 3 then
return
end
trigger = getGpsSpeed()
if recording == 0 and trigger > goproStart then
startGoPro()
recording = 1
end
if recording == 1 and trigger < goproStop then
stopGoPro()
recording = 0
end
end
Excuse the messy and long code.
Currently, I have an issue where the GoPro doesn't turn on when I power up the datalogger. However, if I clear the script and run it from the software, all the commands execute just fine.
I tried polling the log as I turn the car on, but the log doesn't poll until I clear and run the script. Not exactly sure what is going on here. Otherwise the script works perfectly, turns the gopro on and sets all my parameters too!
Hrm, the lua script should run upon power up. Might want to try sprinkling some println() logging messages in there to prove it's working.
Perhaps there's a race condition where the wifi module isn't yet ready to accept commands from the Lua script when it's first powered up. Some of those debug logging messages will help shed light on it.
boggie1688
Stupid me!
I had my laptop plugged in via USB! I though I was turning the RCP3 of when I turned the car off, but my laptop was keeping the unit powered!!!
:oops: :lol:
No worries, I do that *all the time* :)
boggie1688
https://youtu.be/3E4tweXkLZI
Yes!
Probably could be tweaked to speed it up but still not bad.
Alright, that's great! powering it up is definitely a bonus.
It has no detrimental effect if the camera is already powered on, and all of those commands are set?
I've pointed another fellow to this thread to confirm if the command to set camera mode is the same as what you're doing here; apparently there are newer GoPros that need additional commands before video can start recording; perhaps you've solved that here.
boggie1688
As far as I could tell, running the command twice didn't adversely affect the GoPro.
I reference this website for the httpGet commands.
http://hobbyrobo.com/gopro-url-commands/
I also came across this when hunting for commands. He appears to have figured out all the commands for all the GoPro generations.
https://github.com/KonradIT/goprowifihack
Here is one specific to the Hero 5.
https://github.com/KonradIT/goprowifiha ... ommands.md
It appears the Hero4 and Hero 5 share the same Wifi Commands:
I'll play around with it again tomorrow and see if I can speed it up a bit. I also want to have the RCP3 turn the GoPro off when I turn the car off. Going to see if there is a way to have that work.[/url]
jeffmcaffer
Post by jeffmcaffer »
I just posted a Wake on LAN snippet in another thread. Check out viewtopic.php?t=5398.
I've been working with a Session but the same sort of thing should work for other cameras needing WoL.
Pro3 #24
