Hi, I recently bought a RaceCapture Track logger. I am currently trying to log the individual wheel speed of my 2013 427 convertible (LS7) that I believe uses the LS2 ECU. I used to log this with my RT DL1. Where can I find a list of CAN IDs?
Alex
LS2 CAN ID list needed
You might want to see if there's any raw data coming down the wire with our CAN logging script:
https://wiki.autosportlabs.com/CAN_Bus_logger
Related: https://wiki.autosportlabs.com/CAN_Bus_Integration
Do you have a link to default the set up file that's loaded at the factory for use with Solostorm? I changed a few things and didn't save the original set-up file. I actually know better. We are trying to test for Solo Nats and I don't have time to finish the custom stuff right now. Race Capture Track. Thanks
