I am using the stock e46 M3 sensor, which the AEM infinity ECU can see.
But the AEM infinity does not output that data onto the CAN BUS like the stock e46 ECU does.
That's the problem
AEM Infinity CAN channel mapping script
Ok. In that case, you should be able to tap into the CAN bus data that is output by the E46 and map it in the same way as we do with our regular E46 mapping.
Is all of this happening on the same CAN bus? If you're already connected to the same CAN bus that the steering angle sensor and the ECU is on, then you should see the E46 steering angle sensor data, no need for it to be re-broadcast from the AEM system.
After my last post i got an email from AEM. They will be enabling the steering angle sensor data to be broadcast on the AEMnet CAN with the next software/firmware update for the AEM infinity for the e46.
So I think I will wait for that to happen rather than trying to tap the other wires as it is not that critical to have immediately.
