I got it "fixed". Now the shift light represents the 4000 to 7000 range. The first LED turns on at 4000 rpm. Anything below 4000 rpm is ignored by the script.
Basically, the ShiftX2 is configured to work from 0 to 3000 rpm and my script converts the RPM value by subtracting 4000 from the real value. If RPM is below 4000, ShiftX2 receives 0 as value.
Here is my full script, before minifier and using a static oil pressure value as temporary solution, because I didn't have time to install the sensor. Sorry about the comments in portuguese.
--======================================================Main data======================================================
--Inicializa CAN e define TickRate==
collectgarbage()
--println("start.."..collectgarbage("count")*1024)
initCAN(0, 500000)
initCAN(1, 500000)
setTickRate(50)
sleep(5000)
--==Declaracao de variaveis==
local vIPW, vRPM_H, vRPM_L, vRPM, vCoolant, vSSTTemp, vBoost = 0,0,0,0,0,0,0
--==Linha comentada traz todos os canais de RAX. Linha seguinte traz apenas os utilizados==
--local cSTFT, cLTFTcurrent, cLTFTidle, cLTFTcruise, cLoad, cAFR, cIPW, cAFRMAP, cLoadTiming, cTiming, cKnock, cRPM, cIDC, cBaro, cMAP, cBoost, cWGDC, cMAF, cInVVTtarget, cInVVTcurr, cExVVTtarget, cExVVTcurr, cTPS, cAPP, cIAT, cWGDCcorr, cSpeed, cBatteryECU, cCoolant, cMAT, cMAPcalc, cIMAPcalc, cMAFcalc, cChosenCalc, cSSTTemp
local cSTFT, cLTFTcurrent, cLTFTidle, cLTFTcruise, cLoad, cAFR, cIPW, cAFRMAP, cLoadTiming, cTiming, cKnock, cRPM, cIDC, cBaro, cMAP, cBoost, cWGDC, cMAF, cTPS, cAPP, cIAT, cWGDCcorr, cSpeed, cBatteryECU, cCoolant, cMAT, cMAPcalc, cIMAPcalc, cMAFcalc, cChosenCalc, cSSTTemp
--==Variaveis de canal auxiliar para acompanhamento de taxa de atualizacao==
--local counter = 0
--local cRefresh = addChannel("Refresh", 50,0)
--==Criacao de canais RAX==
--==RAX A==
cSTFT = addChannel("STFT", 50,2)
cLTFTcurrent = addChannel("LTFTcurrent", 50,2)
cLTFTidle = addChannel("LTFTidle", 50,2)
cLTFTcruise = addChannel("LTFTcruise", 50,2)
--==RAX B==
cLoad = addChannel("Load", 50,2)
cAFR = addChannel("AFR", 50,2)
cIPW = addChannel("IPW", 50,1)
cAFRMAP = addChannel("AFRMAP", 50,2)
--==RAX C==
cLoadTiming = addChannel("LoadTiming", 50,2)
cTiming = addChannel("Timing", 50,0)
cKnock = addChannel("Knock", 50,0,0,20,"count")
cRPM = addChannel("RPM",50,0,0,8000,"RPM")
cIDC = addChannel("IDC", 50,1)
--==RAX D==
cBaro = addChannel("Baro", 50,2)
cMAP = addChannel("MAP", 50,2)
cBoost = addChannel("Boost", 50,2)
cWGDC = addChannel("WGDC", 50,1)
cMAF = addChannel("MAF", 50,2)
--==RAX E==
--cInVVTtarget = addChannel("InVVTtarget", 50,1)
--cInVVTcurr = addChannel("InVVTcurr", 50,1)
--cExVVTtarget = addChannel("ExVVTtarget", 50,1)
--cExVVTcurr = addChannel("ExVVTcurr", 50,1)
--==RAX F==
cTPS = addChannel("TPS", 50,1)
cAPP = addChannel("APP", 50,1)
cIAT = addChannel("IAT", 50,0)
cWGDCcorr = addChannel("WGDCcorr", 50,1)
--==RAX G==
cSpeed = addChannel("Speed", 50,0)
cBatteryECU = addChannel("BatteryECU", 50,2)
cCoolant = addChannel("Coolant", 50,0)
cMAT = addChannel("MAT", 50,0)
--==RAX H==
cMAPcalc = addChannel("MAPcalc", 50,2)
cIMAPcalc = addChannel("IMAPcalc", 50,2)
cMAFcalc = addChannel("MAFcalc", 50,2)
cChosenCalc = addChannel("ChosenCalc", 50,2)
--==Criacao de canais SST==
--println("after rax.."..collectgarbage("count")*1024)
cSSTTemp = addChannel("SSTTemp",1,0)
--==Funcao para fazer a chamada e receber os valores de RAX==
local function getRAXCAN(RAXaddress)
local res, id, ext, data
res = txCAN(0,2016,0,{5,35,128,81,RAXaddress,4,255,255},100)
if res == 1 then
id,ext,data = rxCAN(0,100)
else
data = nil
end
return data
end
--println("aftersst.."..collectgarbage("count")*1024)
--==Rotina para atualizar os canais RAX==
local function getRAX()
local data,vMAP,vBaro
--==RAX A==
data = getRAXCAN(172)
if data ~= nil then
setChannel(cSTFT,(data[3]* 25/128)-25)
setChannel(cLTFTcurrent,(data[4]* 25/128)-25)
setChannel(cLTFTidle,(data[5]* 25/128)-25)
setChannel(cLTFTcruise,(data[6]* 25/128)-25)
end
--==RAX B==
data = getRAXCAN(168)
if data ~= nil then
setChannel(cLoad,data[3]*25/16)
setChannel(cAFR,data[6]*0.0392+9.8)
vIPW = data[4]/10
setChannel(cIPW,vIPW)
setChannel(cAFRMAP,(14.7*128)/data[5])
end
--==RAX C==
data = getRAXCAN(176)
if data ~= nil then
--data[6] = data[6] + ((data[5]%8)*256) Esta linha traz a definicao antes da separacao em High e Low Byte para Shift Light
vRPM_H = data[5]%8
vRPM_L = data[6]
data[5] = math.floor(data[5]/8) + ((data[4]%2)*32)
data[4] = math.floor(data[4]/2)
vRPM = ((vRPM_H*256)+vRPM_L)*125/16
setChannel(cLoadTiming,data[3]* 25/16)
setChannel(cTiming,data[4] - 20)
setChannel(cKnock,data[5])
setChannel(cRPM,vRPM)
setChannel(cIDC,vIPW*vRPM/1200)
end
--==RAX D==
data = getRAXCAN(180)
if data ~= nil then
data[3] = (data[3]*2) + math.floor(data[4]/128)
if data[4] > 128 then
data[4] = data[4] - 128
end
vMAP = data[3]* 0.096487
vBaro = (data[4]+90)* 0.072519
vBoost = vMAP - vBaro
setChannel(cBaro,vBaro)
setChannel(cMAP,vMAP)
setChannel(cBoost,vBoost)
setChannel(cWGDC,data[5]/2)
setChannel(cMAF,data[6]*5/255)
end
--==RAX E==
-- data = getRAXCAN(184)
-- if data ~= nil then
-- setChannel(cInVVTtarget,(data[3]-16)*5/32)
-- setChannel(cInVVTcurr,(data[5]-16)*5/32)
-- setChannel(cExVVTtarget,(16-data[4])*5/32)
-- setChannel(cExVVTcurr,(16-data[6])*5/32)
-- end
--==RAX F==
data = getRAXCAN(188)
if data ~= nil then
setChannel(cTPS,data[3]*100/255)
setChannel(cAPP,(data[4]-32)*129/255)
setChannel(cIAT,data[5]-40)
setChannel(cWGDCcorr,(data[6]/2)-64)
end
--==RAX G==
data = getRAXCAN(192)
if data ~= nil then
vCoolant = data[5]-40
setChannel(cSpeed,data[3]*2)
setChannel(cBatteryECU,data[4]*18.7/255)
setChannel(cCoolant,vCoolant)
setChannel(cMAT,data[6]-40)
end
--==RAX H==
data = getRAXCAN(196)
if data ~= nil then
setChannel(cMAPcalc,data[3]*25/16)
setChannel(cIMAPcalc,data[4]*25/16)
setChannel(cMAFcalc,data[5]*25/16)
setChannel(cChosenCalc,data[6]*25/16)
end
end
--==Rotina para atualizar os canais SST==
local function getSST()
res = txCAN(0, 2017, 0, {2,33,51,255,255,4,255,255},100)
if res == 1 then
else
data = nil
end
if data ~= nil then
vSSTTemp = data[4]-50
setChannel(cSSTTemp,vSSTTemp)
end
end
--==Rotina para atualizar os canais analogicos e demais valores para o ShiftX2==
local function UpdateAlerts()
local AlertL, AlertR, vOilTemp, vFuelPress, vFuelTemp, vOilPress, vFuelPressDelta, OilPressWarning
--==Alerta Esquerda==
--vOilTemp = getAnalog(5)
vOilTemp = 80
AlertL = 1
if (vCoolant < 75 or vOilTemp < 75 or vSSTTemp < 75) then AlertL = 2 end
if (vCoolant > 100 or vOilTemp > 100 or vSSTTemp > 120) then AlertL = 3 end
if (vCoolant > 110 or vOilTemp > 110 or vSSTTemp > 130) then AlertL = 4 end
--==Alerta Direita==
vFuelPress, vFuelTemp, vOilPress = getAnalog(0),getAnalog(1),getAnalog(4)
vFuelPressDelta = vFuelPress - vBoost
--==Explicacao da logica==
--Oilpresswarning
--se RPM >= 4000, Oilpress > 80
--se RPM < 4000, Oilpress / RPM > 0.02
OilPressWarning = false
if vRPM >= 4000 and vOilPress < 80 then OilPressWarning = true end
if vRPM < 4000 and vOilPress/vRPM < 0.02 then OilPressWarning = true end
AlertR = 1
if (vFuelTemp > 45 or vFuelPressDelta < 45) then AlertR = 2 end
if (vFuelTemp > 50 or vFuelPressDelta < 40 or OilPressWarning) then AlertR = 3 end
--==Retorno==
return AlertL, AlertR
end
--=======================================================ShiftX2=======================================================
local function sxTx(offset, data)
txCAN(1, 0xE3600 + offset, 1, data)
--sleep(10)
end
--==Inicio Configuracao de start==
--==Configuracao do Shift Light==
--Configuracao considerando inicio em 4000 RPM
sxTx(40,{0,0,0,0,128,1}) -- Corte em 7000 RPM
sxTx(41,{0,0,0,0,0,255,0,0}) --verde em 4000 RPM
sxTx(41,{1,0,0,1,255,255,0,0}) --amarelo em 6000 RPM
sxTx(41,{2,0,128,1,255,0,0,10}) --vermelho piscante em 7000 RPM
--==Configuracao do alerta da esquerda==
sxTx(21,{1,0,2,0,0,0,255,0}) --azul
sxTx(21,{1,1,3,0,255,255,255,0}) --branco
sxTx(21,{1,2,4,0,255,0,0,10}) --vermelho piscante
--==Configuracao do alerta da direita==
sxTx(21,{0,0,2,0,255,255,255,0}) --branco
sxTx(21,{0,1,3,0,255,0,0,10}) --vermelho piscante
--==Fim Configuracao de start==
--==Inicio Configuracao de update==
local function updateShiftX2()
local left, right
left, right = UpdateAlerts()
if vRPM_H < 2 then
sxTx(42,{0,0})
else
sxTx(42,{vRPM_L,vRPM_H-2})
end
sxTx(22,{1,left,0})
sxTx(22,{0,right,0})
end
--==Fim Configuracao de update==
--println("antes de onTick.."..collectgarbage("count")*1024)
--==Funcao onTick==
function onTick()
if getGpio(0) == 0 then startLogging() else stopLogging() end
local UpTime
getSST()
UpTime = getUptime()
repeat
getRAX()
updateShiftX2() -- Funcao do ShiftX2
--==Linhas abaixo para canal auxiliar para acompanhamento de taxa de atualizacao==
--setChannel(cRefresh,counter)
--counter = counter + 1
--if counter == 2000 then
-- counter = 0
--end
--==Continuacao de onTick()==
until getUptime() > UpTime + 1000
collectgarbage()
--println("em onTick.."..collectgarbage("count")*1024)
end
I can't run all RAX logging values because of the memory limit, so I removed the MIVEC channels. It's currently very tight. Besides that, everything seems to be running fine.
